  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Sounds like he's dissing your 20rwkw stickas Cyrus :)
aint dissing...
i'd cover the whole car in stripes so it wudnt be stripes anymore if that were true...
----------------------- <-----speed stripes 3 x 50kw = 151kW... *wait*... hmmm
So? Everyone does, I dun care I think it'll look shit hot and who gives a rats ass what everyone else thinks!!
If I was allowed I would go 2 bigass white racing stripes right down the guts, but I have been threatened with divorce if I do :)
Cyrus just let me know when hes going to fit them etc and i'll transfer the money into his account or just give it to you which ever is easiest
I'll prolly pay him and just get you to fix me up sometime :) sound good?
Damn him for putting those stickers on his car! We were going to swap plates so I could go to willowbank and race his car and then change the plates over and people think it was me!
ahhh the perfect crime.... no-one would have noticed that Erin :)
