  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I got approached by the SVD club today...they caught me at a servo!
Looks like they're trying to register their club properly up here v'soon...they must have been influenced by Adrian..they were armed with flyers as well :(
nice work , the rice KING you are my friend , my line has finaly gone throo complience and will be in the work shop next weekend , so I think I am going to take the week off to go and work on it while it is in there .
At the moment I have hired a AWD magna too throw around it's black too , I have just brought a drift wing ( the little one ) and a el dash like NA33's from ARESSPEED .
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
