  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I havent even met u guys, and I'm already thinkin about runnin u both over...
In my camry of course! :(
you dun wanna do that.... one's our hero and moderator... and the other is my lover :)
touch them and i will set the entire brissy crew on you :jk:
you dun wanna do that.... one's our hero and moderator... and the other is my lover :(
then i'll be sure to run over u first...
and I'm in no skyline so my camry can be ontop of you :)
is lil Nicky ok?
i was gunna get an M-Spec then thought otherwise coz of insurance...
thinking about a R34 GT-t engine transplant and a T67 ? :(
not netime soon though.. try like 1-2 years down the track
big plans. you gotta do the brakes as well though. 2 pots front and 1 pot rear is not sufficient enough for that kinda power....
and I'm in no skyline so my camry can be ontop of you :(
is lil Nicky ok?
yea.. he's fine.... 1.2k worth of repairs and he's back on the road again... he's getting better though....
i'm his freaking guardian angel....
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
