  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Eug   Be very careful!! this is a dangerous crew your getting mixed up with........I fear for your very soul!!!
no fear, coz i have no soul!! :( hehe
(this'll be like in 5 yrs though)
yeh.. gunna do the whole lot. Strut tops.. reinforcement back to the firewall.
etc. :) very $$ though..
Eug!!    I mean it!!    they drink coffee on Park rd with their little pinkies sticking out!!!  and they pick fights with fat women!!!
really? hahaha.. sounds like fun...
*psst.. u being serious serious. or joking serious* :(
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
