  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I saw one is Bris with the same stripes , diff kolor o'course , do you know him ?
I tried to stop to talk to him and have a look but he was just pulling out of Northfield car radio shop.
Run out of fliers atm sorry, but no the only car I have seen with 2 big fat stripes al la dodge viper style is a silver VS with RED stripes, looks awesome!! but other than that have not seen any other cars with the same stile of racing stripes :(
It was a black or dark kolor of some kind , it was a line , and it had the strips I can be sure of that , don't know what kolor the strips were , maybe silver or gray ?? deffinetly was not green so I think you are safe there
Dammit who was questioning my STi ownage!!! :)
He meant business, young guy not afraid of laying into it...was revving the tits off the thing....I was shocked myself that it didn't blow me away. Maybe the N/A-turbo holds more secrets than us mere mortals can accept :(
you were running an STI ? :-)
Well i don't know, everybody says how fast they are.. yet I once saw one fully decked out and obviously had tens of thousands thrown at it and it only did mid 12's i think. And he had plenty of runs.
And i have "beaten" them (under unsure drag conditions) too .. so maybe they aren't as quick as most people make out in a straight line maybe?
yeah the one in speed magazine had loads spent on it and only ran 12.9...so yeah I reckon it's all rumours about how quick they are....maybe if they had a rev-limiter launch it could gain a bit in traction advantage?
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
