  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I'll consider the extractors after i find out sum info, on my
bloody JASMA exhaust.. no one knows anything abt them.
and I got no money atm :rofl: I'm sure u can find a chick or
two to shout u lunch, if u take em for a ride..
(whats with the points system? I only got 15... how'd u guys
get 90+)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
