  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
anyone here know why when the adsl modem is on my computer everyone can use the adsl on everyother computer in the house, when i put it on mums computer everyone can use it again but only on my computer does it drop out every 5min :@
dodgy connection in ur network cables? or ur getting pinged out?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
