hmnmmmmm when I go to buy stuff I get this:
http://www.skylinesaustralia.com/forums/us...do=richestusers 220.244.224.9 /forums/uttstore.php?do=a&aid=7 www.skylinesaustralia.com Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0; .NET CLR 1.1.4322) 404
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
