  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
glenn i got an email from that guy about the black 32 for $16k he said i should come take a look then make him an offer
if i have time... i will go down with you to check it out.... if not, ask someone in here to accompany you.
glenn leg is a fair bit better now, just overly tired from work today tho
and sad i cant come cruisin
will it be ready in time for sunday cruise?
hmm.... i'm not a firm attendee myself as well... still waiting for some stuffs to clear first....
