  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hey Warwick! Where were you yesterday? We had HEAPS of fun :D
The new cooler is great :D I'm in love!
I would have liked to come, but was in Sydney for the weekend...hard to pass up a free weekend at the Park Hyatt
and I am extremely jealous of your new cooler :)
cyrus: thanks!
26/2/04
Genuine N1 Nissan Water Pump - $156
GTR Timing Belt - $98 (Gav only uses GTR belts)
I also had to replace the two tensioners too all up was $950 for:
timing belt
water pump
2 x tensioners
alt, air and ps belts
coolant inhibitor & bleed cooling
radiator cap
labour
I... Of course... was only reffering to thursday nights :D
Haha...
Yes well *cough* Brisbane's thursday night organisings are a bit uhm... *cough*
The only I can think of that actually "went" somewhere was Gordo's one. *shrugs*
As I said to Cyrus when he was whinging about brisbane's organising skills, we are in a city.. where there aren't many good places to go cruising to for fun. Down the coast are big wide open roads with no public around in areas which makes it a lot easier to organise somewhere to go. *shrugs*
Oh wells.
and I am extremely jealous of your new cooler :D
It's very prewdy :) I can't wait to see what it does on wednesday night.. and then again at the next one.
I'm HOPING to have it in for fine tuning on Monday 10th May, then I'll go to the next test and tune after that and the Dyno day. :D
hrmmmm cyrus, mine cost me 350bucks, minus tensioners and pump, but plus gearbox and diff oil and engine oil and filter, and fuel filter
Yeah tensioners alone were friggin nearly $350 one was genuine nissan though Gav explained he tried to find anothe non-genuine, but I wanted the car back so he didnt have time ot source one, meh I am happy with the results so money well spent imho!
yowch! see that is why i have held off :)
how'd you get it done for $350 john? See i was originally going to get him to do all that shit too.. plus install a camgear.. now its got less and less to just the belt and waterpump .. and me doing the other stuff
matt: photoshop is your friend when it comes to maps
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
