  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
or we could work out a contra deal Warwick,
I have access to computer hardware at prices you wouldn't dream about :D
:rofl:maybe we can do a deal on the canvas set I have for Cyrus now that he's gone :D
you didn't want them with tread did you.......
don't payout auto drivers , maybe he can't help it because he has one of those licence's with a big fat A on it , so he is only aloud an auto ...........................
at least he has a skyline in the drive way unlike myself
Tread??????
Please explain..... is that the stuff I have on my tyres for about two weeks?
Blah blah blah
i.e I am a big girl who can't pass the Manual Driving test :D
why do you have spare seats?
In case i get too excited one night whilst driving :D
no.. actually i bought them a couple of months back as they were cheap and you know how you go "hmm, may need them one day, they're cheap - hell i'll just buy them right now!" (which always seems so great at the time), and at the time i was thinking i was probably going to buy a 180sx.. to replace the liner.. they have poxy seats
but now i have different plans.
I was going to make them into office chairs.. now that could have been cool..
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
