  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Glenn - I AM STILL BEATING YOU, YOU LAZY WHORE!
Top ten people without lives:
User Name Posts
chaos 3119
Cyrice 2552
Genesis® 2450
Lazy-Bastard 2112
strutto 2072
BelGarion 1754
SmoothLine 1674
Nexus9 1574
predator 1543
NA_R33 1167
bight all bestter get at least 2 hours sleep till work, hmmm tomorrow is going to be super dooper strong coffee days, see if I can break my record, alwasy wanted to just try 1/3 cup of coffee, 1/2 cup sugar little bit of milk and little bit of water :D
Will post results later on today :D
Man Phat mirage can drive that little thing can't he
Thanks again Cyrice for last night that was cool , hope I didn't make you to jelous showing off my little hord of bits and knobs
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
