  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
eug: don't have rpoper pix.. i'll take em tomorrow.
basically just multispoke thingos.. with the "S" in the centrecaps.. they are only 15". Like i said they'd only be really for drifting, burnouts or the drags, they're not really a "look at me" rim to drive around with if that is what u wanted. I was asking $250 .. but i'd take $150 for the them.
Eugene, best to do some research, alot of people have good things to say about Bridgestone Potenza (SO2, SO3), Michelin Precendas, Toyo Trampios(?). All depend what you expect from them and how deep your wallet is. I love the Yoko ES100s on the GTR but they are starting to get a little $$$ and I fear the mileage won't be that great, but the grip is fantastic.
all have ups and downs..
everybody wants a perfect long last tyre that is cheap, good in the wet, good on the track, grips well on the road, and under every condition -- not going to happen.
check the "tyre and suspension" area and old threads in there, there is alot of useful stuff i learned in there.
yer.. thats what i thought - these are just for ****ing around with, not looking good. thats what i got em for.
well as a *rough* guide, i picked up my set of 2nd hand set of 17x8 chrome rims for $1000. Then about $800 for tyres (got cheap us $200 Falken ZE326 which i would NOT recommenD). So around $1800 all up.
check board.performanceforums.com (when its back up!) they have a really good wheel forum with some good deals on there. That is where i got mine acutally i think way back when
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
