  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
A mate had an electric one than could reach 60-70 kmh....
Mine is stock 36 volts with aftermarket 11'' chromies, lol
I have a stock electic one as well, it too has chromies dunno the size....clocked it doing 33km/h (down a hill) :)
151 isnt the normal bicardi brezzer shit or whatever this is different
Yeah its a golden rum, like bundaberg rum... Just a slightly stronger proof, but no where near 80% THe normal Bacardi is bacardi light... which is 36% alc vol...
The best golden rum is bacardi gold....
I am a bacardi expert btw :)
OK Mr bicardi just searched google and found this "Bacardi 151 Rum is a high proof (75.5% alc/volume), dark aromatic rum produced by Bacardi. It is a form of overproof rum, which is not available in several countries due to it's excessive alcohol content."
i was close :)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
