  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Glenn is stoned? At work? Micheal Jordan?
*shrugs* :wavey:
cant sleep last night... so decided to watch my 'Best of Michael Jordan' DVDs... finally able to sleep @ 3...... got up @ 6.30am..... in office now...stoned in front of computer....
and i have got a 3 hrs lecture later..... weeeEEee....
i need pills~~
actually cyrice - i think your sig needs to be de-bigged.. now its annoying
PM squizz and ask him to remove it, he seems to like putting it there :D
As well as 0wning my avatar and whatever else he likes, stop fighting it, and JOIN THE "I Love Squiiz Wang" CULT NOW! :)
