  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Anyone know how far you can drive on the fuel ligh on, i have braved 40kms before chickening out, i dont have a jerry can otherwise I would, so that I know :)
Hey I have an 32. I have driven between oxley and St Lucia 5 times after fuel light. (maybe 50 kms-also traffic) Also from Redbank to Gatton on fuel light and then around gatton campus for 1/2 hour (hairy-looking for my prac group) That would be a 100 kms, and that is at 140 most of way. Ran out for first time in my car few days ago, But my last car was a newie too and I ran out nearly every week without fail. Never had a problem with fuel pump.
Source of problem: first car on gas, so can just switch tanks.
Get gas then you can get km travelled after fuel light for every driving situation!!!
hey Anthony,   Hope you and Michelle had a good time out with us last night. :)
Had a great time. Thought it got a bit hairy a few times (and I was in the slow group) - but I love hairy. Getting springs and suspension done this week. Anthony has gone to Townsville for a holiday (leaving me with exams) Will you all be meeting at 7.30 at Milton macca's next Thursday. Gonna try and leave the kids at home, but they have become little skyline fanatics so may be hard.
isnt like the dirty petrol towards the bottom of the tank? like all the sediments n stuff?
so if u get low enough wudnt all that get into the special RB engine?? -_-
Saw ur car parked outside the childcare centre at UQ on Monday morning SXE32.
hey chris.. do you know if Couriers Please deliver to Melb? and i can I use the company account to do it on friday? :)
(I'll pay whatever it costs to do it).
I need a place to ship my sideskirts to somebody, but most don't take private deliveries (e.g. you need to have an account with them)
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
