  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeah i am here, frigging working at this hour should be banned, gott be at work in 4hrs 30mins, as one of the servers has died, VNC'd in and did a PDC to SDC swap over and verything looks like its working, night shift arent complaining so i an draggin my stripy ass back to bed!
I pity da fool with an NT domain...
Care to predict the future Prof?
Not really :P
But .....
We will go through a state of wax and wane.
It is human nature to group together, then fragment within the group, to form allegiances and establish a hierachy of sorts.
Once a loose agreement of idealogies ( conciouos or unconciouosly) is established, the first act of the new "clique" is to dampen any possible challenge to the group leadership from any new comers, whilst the infighting within the "clique" (again concious or unconciously) for supremecy takes place.
It is the role of the elders in this society to moderate the extremism of the intemperate.
Shall I go further or am I boring you :P
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
