  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah.. MJ..and he has a HKS cam gear to go on to.. last time i heard from him..
can't sell car with 98,000km on the clock and no service, and not running anywhere near its full potential :rolleyes: unless i took a bite in the ass and sold it for a stupid price.
i heard greenline was really slow and they had troubles? so i went nengun, now i am waiting on them.. Why am i always the guy that gets screwed over?? :)
anyone feel up to installing new turbo, front mount, plenum, fuel pump etc etc for me?
I'll buy you a beer :rolleyes:
been there man
plenum = bitch, and most the other stuf is just as much a bastard to do
why u think i did it myself with the aid of a friend? too long to wait to get it done, something has to be said for just dumping it at a mechanics and sayin call me when its done tho
BELIEVE ME
i think they must be good sometimes and at others shithouse.. i have a feeling some weeks he's not even in the office..
and there is no direct email to contact them on.. just a yahoo address.. now that is service with a capital S
Hey James,
Yeah I am at that stage in life where I don't want to get my hands dirty and I would rather someone just did it all for me :rolleyes:
Damn my parents for bringing me up to avoid manual labour at all costs :)
fuel pump took me 90 mins and i didn't really know what i was doing.. intercooler should be 60min job save the cutting if you have a stock front bar, especially if its a full kit. It should be bolt and go..
Well that's already 3 hours of my life I will never get back
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
