  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i'm drinking a UDL..
what stock stuff you got James?? if people are gonna be tight ass pricks (and they will), i'll just destroy my car and return it to stock and flog off for $17 or 18k just with kit and no performance items.
i was thinking on the way home i could do "swap stock item + cash for my aftermarket item"..
