go front strut bar and sway bars.... front and back.... even with stand springs and shocks, you will still easily out manevour most cars....
you trying to get me broke?! :)
you keep giving me ideas to add more mods to the car, probably end up doing a RB25DET engine transplant and a T88 and nos.... :headspin:
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeh but dont forget exhaust...will be lower than your standard one
not really benny boy... max piping size for NA should only be 2.25 inch catback and muffler size is almost same as stock....
you go anything more than 2.25, you will lose back pressure.... less torqy....
ME giving you ideas?? :confused:
i would go handling first..... no point spending thousands to squeeze a few more KWs outa the car...
awesome handling makes you a better driver...
I've got a twin cannister 3.5" exhaust sitting in the garage :)
ya, I'm going for tyres first Glenn costing me a butt load too.... almost half my uni tuition.
can sometimes even be just be the gaskets or rubber mountings.. gaskets are like $2.50 to replace
where can i get this checked out? at a normal garage???
yup.. not cheap..
krawler: no.. they're just spring and shock setup.. i sold my old set for $200, they were sitting around for ages
Doesnt coil over simply mean the coil is over the shock?
Meaning that most cars are coil over factory.. The term coil over is normally targetting adjustable gear though.
i know... It was on the NA, but got it taken off for compliancing.. and power loss.
now i'm stuck with a stupid rattle.
get 2 jacks and a creepboard.... rip out the heat shield....
if not the heat shield... hammer the resonator gently to check for rattling...
i think the difference is.. with coilovers, the shock is actually welded to the bottom of the spring, and they are basically one unit and cannot be separated. Most things can be adjustable.
With a spring and shock setup the springs and shocks can be separated and changed independently. In that setup you can adjust the shock, but not the actually spring height or anything like that.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
