  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i think the difference is.. with coilovers, the shock is actually welded to the bottom of the spring, and they are basically one unit and cannot be separated. Most things can be adjustable.
With a spring and shock setup the springs and shocks can be separated and changed independently. In that setup you can adjust the shock, but not the actually spring height or anything like that.
Nah, people just use the term for the aftermarket adj one. My APEXi coilovers are identical to the standard ones except the spring seat is threaded and the adjustable shock rate knob at the bottom of the shock housing. Ohlins even use the same tapered spring like the stock springs.
jl: so you can actually remove the center to get it reconditioned with your springs?
I thought that was the reason why adjustable coilovers couldn't be reconditioned (one unit), whereas with a totally seperate coil and spring you can mix and match the spring and the actual shock absorber??
I had mine reconditioned before I put them in and had the original Apex spring changed to king springs of custom rate to improve ride. Since then I have also changed the springs at the front myself. People don't recon them because they haven't seen that brand before. The Ohlin, Tein and HKS ones I have seen were all the same. Otherwise it would make changing the spring rates difficult, which would take away from there "racing" purpose. It took me 1.5hr to change the front springs on the R with the APEXi coilovers, from wheel off to wheel on.
These guys are one of the few that will reco almost any coilover:- http://www.shockreco.com.au/
ahhh.. cool i didn't know you could do that.
yep.. if i ever work on the handling of the 31 i'm going to try swap things myself to save labour costs. Generally just need a spring compressor don't you but otherwise its just bolts in and out?
those guys sound like a good group to keep in mind.
i was always wondering whether i could get my Zeals reco'ed as they are $4k suspension (apparently) but nobody knew of anywhere in melbourne that would touch them. Basically a few people said "just throw them out and buy something local"
Yeah, spring compressors are cheap and a one off expense, I got mine from Repco for about $50, they were the cheapest, but for what I want they are fine, I think supa cheap has them for even less. Its kinda fun doing it youself, playing with the spring rates in the R has been fun, have learnt heaps about how spring rates effect the handling, I think I have it about just right for 95% road use, 5% track use. I really like a nice handling car, it gives you so much more confidence, and make you look like you are a better driver than you are :) .
They are just too expensive to replace, they can do all sorts of things. I have been talking to him about re-valving the APEXi ones as I think they could do with a little more rebound control, they only need the unit for a day to do that for me. As long as the shock housing hasn't been damaged its all good.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
