  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Chris, how's things? I've got some minor tech problems today but nothing I can't fix at the expense of not getting all my regualr work done. Farkin power surges. Well at least the net's workin'. :) :)
Gotta love power surges :)
Everytime there is a lightning storm I am guaranteed more income as people come into replace their fried componentry
Everything was going well, until the lights flickered, and the aircon did the minor interruption sound. GRRRRRRR. Meh. I'll fix it tomorrow. it's not like we NEED a mail server anyway.
Its my cousin, we go out together.... But im sure one moe in the party will be fine with her...
:aroused:
Do you and your cousin like spitroast??????? Smoothline. are you smooth....... you know where..... :aroused:
and Ben toilet candy is the pink blocks that you piss on. Now steal some. The whole point is to steal something that has absoluteley no value to you whatsoever that they are going to have to replace once you steal it.
Ben, hope you dont suffere from withdrawal symptoms, as I dont have a puter you can access at home, just a company lappie, and cant let you use that, for reasons which I can explain later, but yeah sorry dude :)
On the flip side, i'll let me catch up to you on the post count! :)
wont be out tonite cyrice....i'll talk to you tomorrow after work...mum will be dropping me off probably saturday arvo
I wont be home tomorrow night though, hmmmmmmm I am passing through your way Saturday arvo sometime, i could pick you up? But I'll have my kids and all their stuff half filling the car so wont have too much room, dunno if our roomate will be there either, so yeah we'll work something out :)
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
