  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I can't believe they paid someone $350. FFS. Show me how to do it and I'll do it.
I've even been dropping hints that andrew knows how to do computer stuff and he can do it.
But far out. $350, that's hell rich for like 30 minute sof fiddling with a computer. AND all he did to test the email was send a message from my email to my email. Also, he didn't set my servers up properly. Lucky I'm a smart cookie and knew how to do it!! *taps nose*
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
