  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
sup vin.  were you at p/road lanst night???? I hope you found what you were after saturday after you left.
who's Vin?? Yeah I was there last night... but you guys had already left (got Rob's message a lil bit too late). Was there with a friend.
What was I looking for?
NTP - Network Time Protocol
Lets my server sync time with other server which sync with other servers, which sync with other servers, which sync with other servers so that we all have servers running on the correct time which is GMT adjusted.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
