  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hi James, meh still sore. I have to ice it every day after work as it swells quite a bit. At least I can walk around without a limp now.
Don't know whether I should ask...... but, how is your car situation coming along?
Incidently a description of me :)
Haha..
Sorry I've just come to the computer. I found this funny. I giggled :rofl:
I've been cutting up paper for my invitations. I dont know how straight they are, I guess I'll find out when I go to put them together :confused:
Makes you think when others cars are stolen. I wouldnt own a Skyline if it were to be left in a driveway or on the street.
Same the only car I leave outside in confidence is the Gemini Van. Dirty, smelly thing it is. Bit scary when you here them go, especially when it is so close to home.
you know the funny thing though I have seen one of these old gem's roof down burnt out the other day with motor g/box every thing still in it
Yeah, I had a guy hit me up about the Gemini once doing a sub-division at sumner park, said it was a yellow van just like mine and had been stolen that night, seriously, you would have to be desperate to grab mine, it is sooooo dusty inside you have to wipe the dash just to see how fast you are going.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
