  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
cool, i wrang up his place like last week and they were shut, is he sic or sumthin, i need to get my clutch fixed:(
They were closed for a week last week.
They are open again now but I think theres a bit of a backlog in repairs and services now.
I just suggest you ring sometime in the next few hours and speak to Amanda. She'll let you know what's happening.
while you're on the phone.. ask what is happening with mine !
i'm so in the dark at the moment about mine - i spoke to gavin on tuesday arvo. He said the work had been done but there was a strange backpressure problem in the exhaust (possible a stuffed muffler or cat). He was going to get some of the guys to look at it when they were free.. but since then.. nothing :)
so its still sitting there..
aaahhhh so thats your red 33 i spilt beer into and all over the seats :P
I am probably going with ABS as I do not think Gavin can beat thier price that Smooth knocked them down to!!
Yo Smooth you are a CHAMP! Rang up the same ABS and he will do the same price, so I rang up about 50 different places they all are getting back to me when they get prices but I dun think they can beat your price, which is my price too :)
hahahaha niice! :P
Im going to ask to get mine done cheaper now lmao...
Glad my negiotiating could be of assistance...
i keep changing it from Ultimate Whore to I HAVE A BIG GAY WING or FORDS ROCK .... n stuff .... but now ive run out of points - so im trying to get people to do it for me or sign their points over to me.
Together we wont let him win!!
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
