  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
was just wondering why society frowns upon the devotion of real anorexics, and in saying that I mean the ones with suficcient devotion to starve themselves thin, and yet society proclaims ad good and just the same sort of madness that it takes to be brilliant and churn out straight sevens at university. Was at a graduation ceremony for honours a while ago and the dux of the class had a gpa of 7 which means she didn't get anything but 7's for the whole degree.
In this day and age of obecity I think we should champion Anorexics with the devotion to stick with it, and frown upon the obece that lack the self discipline to get with the program.
thoughts chris.
Who says that the obese are no less driven than an anorexic?
I would assume that the same disorder that requires/allows you to absolutely destroy yourself would be applicable to a morbidly obese person too.
I don't think that your avaerage person is capable of the dedication that it would take to be corpulent to the same reverse degree.
Any excessiveness is frowned upon by society for good reason, whether it is anorexia, obesity, workaholism, greed, etc, etc.
Different sides of the same coin.
This person who had a high GPA across the board, is there any moderation in this persons life or did they devote everything they had to atttaining those marks?
Sure good marks would indicate a successful future, but against what measure? High paying job but no life outside that job (i.e die alone but rich).
Moderation is the key, but it is so easy to lose sight of.
1. The obece are not driven. Often obecity comes out of a sedentary lifestyle and lazyness more than anythine else. Also the undereducated are far more likely to be obece than the well educated and more fortunate. It tends to be a dizease of the lower calsses and the less socioeconomically endowed groups of society but times they are a changing and that no longer rings true.
2. Thus these people are the ones with devotion. We should really take them around to schools as motivational speakers
3. excessiveness in terms of finding a solution to a problem or artwork tends to be champpioned. Many of the great artists and poets of the world were mentally unwell and yet we appreciate their work.
yes granted everything has a price.
I think another point is how society can turn a blind eye to its set of double standards and the question of how our value system became so skewed. Once again we are brought back to the question of intent and the idea of doing all the right things for all the wrong reasons.
don't know if you'll read this but thanks for the effort in your response.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
