  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I had a pie too.
And damned if theres any psychology reason behind me being a fat prick, its just cause I like pies and doing ****-all. Dont analyze dammit, just get stuck in and enjoy the lifes pleasures.
Fit and healthy is for old people who are getting scared of dying of a heart attack :)
why is it called "team shitbox" then :)
wasnt there a crew of people that did actually have shitboxes out there? like $500 crappers.. or in fact like my r31 :)
Hehehe, this is pretty funny aye.
Partly its because we all used to have shitboxes, or drive round in our pearents cars (a number of which have stickers on them) Then we started to get jobs, buy cars etc, and we thought hey, lets keep the stickers, and go for the sleeper look! The other reason is, really no one can pay out our cars, if they like them or not. Someone yells out "what a f'ing shitbox!!!" and we can just go, yeah thanks mate, and point to the sticker.
And yes, we are quickly running out of true shitboxes, the orginals are fading, but when we get faster cars, we will all buy new shitboxes as run abouts.
Its really just a joke between a few mates that grew in to something bigger.
ahhh... i see.... well i dub you guys "Team Box" then.. lol
yeah, its a little like that.. what was once your only good car becomes ur 2nd car :)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
