  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
BUT I DO HAVE TO ASK MYSELF.. WHY THE **** DO I BOOK MYSELF IN FOR REPEATED PUNISHMENT?!!
agggg...
:stressed:
i hate this web job.. worst ever web job ever :P time quoted = gone many many hours ago.. time to go = who knows! agg :P
if the new version is 2.5L which they are talking about could be bit better.
I'm not sure how much they have changed the formula over the years?? Each one looks only visually different to me, same basic engine with a few drivetrain improvements along the way.
is it just me or this place really slow tonight?
umm.. now i check, its the STi that is 2.5L now... not the standard WRX.
makes mental note to probably have 2nd thoughts on dragging an STi next time :P
yea its slow as and im on broadband!!
Hey heard the rumour that gavin woods is being closed down? is it true?
THIS IS NOT TRUE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I WOULD LIKE TO KNOW WHERE YOU HEARD IT FROM
PUTTING OUT FALSE INFORMATION TO THE PUBLIC IS A LEGAL MATTER OK
IF YOU COULD KINDLY CONTACT ME ON 0417760278
I WOULD LIKE TO TALK TO YOU IN PERSON TO CLEAR YOUR CONFUSION
REGARDS
GAVIN WOOD
    • Thanks for the linkie. Certainly always a great deal of help when people post comparisons like these, but I think for now I'll stay away from any semi slicks. I did go ahead and order the sportcontact 7. My buddy has them on his modified A4 and he keeps saying how good they are. For my intended purposes these will probably work real well. I'll report on them once I had the chance to try them out
    • Talk about noisy. Even when I still had the Tomei under the car I could distinctly hear the tires rolling. And I doubt I ever will need maximum grip like on a track. My GTR will maybe never even see the 600hp mark and I need to get used to the car quite a bit before challenging the limits of its handling. For the next winter storage I think I will get a set of these rubber drive-on thingies that have a tire shaped base. Those supposedly really help prevent flat spots.
    • Well our climate is definitely way less hot overall and the weather can be quite picky at times. I just know that during normal road use or even spirited drives there is no way I'd be able to consistently stay in the operating temperature, and constantly changing the tire pressure would also be a royal pain.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
