Man we really need to call up the tv networks, we'd make a fortune as the newest reality tv show, "House of SAU' it's got drama, "Damn you Ben, there's no hot water left :rant:" its got romance, "I love you ben" (ranee) "I love you ranee"(ben), it's got heartbreak, "I thought you loved me ben" (cyrus), even has new people coming and going, its got everything, nice cars! WE'D BE REALITY TV SHOW STARS! Famous for a season :)
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I am serious about it
I already have Cert 1 and 2 in I.T not sure which exact part of IT cause my certificates are at home.
I am lookin at studying it more now would prefer to get a tranieeship but if i cant will quit my job and get a part time job and go to tafe to study it further
yeah.. almost as worthless as the glut of realestate agents these days :)
I'll just have to get all the webcams all setup, and it's gonna be a bit squishy you two in that single bed dont you think............................
now that is wrong.. although i can see Cyrice and Chaos LIVE.com quite soon..
when the realestate crash comes.. you'll all be out on the streets i tells'ya !!
us computer type have been there and its been and gone :)
Wrong. If prices go down then alot of people can no longer afford their homes, hence more sales. If I was still doing it I wouldnt really care if I sold a home for $1.6million or $1.1million. Also the crash started late November last year ;)
Real Estate agents never loose Gman :) Life is funny like that...
Also when the market dies down there is a huge surge in demand for lower cost housing as people downgrade etc etc, thus opening the doors for more low costs developments, again another win... hahahaha
Property 101 for today was hosted by Enrico Rodriguez...
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
