  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
It's not algae but something else?
its called slime :D
this new rep thing is stupid.. now trader ratings I can understand, that makes sense - but just having an arbitary system where people can just screw with your reputation points for fun is just stupid.
If your as fussy as me about my car, I make sure everything is fixed up to as it was before or I'm not a happy little girl!
yeah, its just the little things that can bother you. I think its just the main thing, its the small details that can really bother a customer when u get the car back and something is a little odd.. or not like it was before.
hey ska.. man - november is *so far away* :D but i will wait still.
I HATE female drivers. With a passion. Chicks in zippy cars suck. I reckon every female should have to sit a driving test every year to see whether they can still drive.
i know.. see it all the time.. drive like maniacs, in and out going 130km/hr or sometimes even more. Probably think because they are a chick they can get away with it (well often they do I guess) and the cops will let them off. And its not like you are really driving a really sturdy car, with great brakes, good traction, proper balance, great crash protection and all the rest of it.
i don't think i could ever drive a small car.. just woudln't feel secure.. always feels like its revving off its head and about to blow up with the way you have to drive it to get any form of power.
I know there are some really fast ones out there, but still, not my thing :D
hey ska.. man - november is *so far away* :( but i will wait still.
Well there is always the living room option................................ :D
But yeah I know I had a talk to my other flatmate and told him that we are just waiting for him to find a place and we can move out, but he really is unprepared and has nothing, so yeah I dont expect him to me making and serious moves in the near future :)
lol cy you know how he said he couldnt move with us down the coast cause of centerlink
He actually can...because centerlink is QLD wide and they have an office at nerang i use to get it when i lived down the coast.
NEGATIVE!
He cant move from a place of higher unemployment than he currently is, SO because the rate of unemployment is higher in the Gold Coast than where we are, Centrelink wont pay him for 13.5 weeks if he did decide to move there.
:D
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
