  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
oh well john you're not the only one :) last skidpan day in melb i came out and lost my old front bar... haha. Can take a toll on the car..
mindflux -- there are like relays and things in a separate box (i think) which you could look at. I know in my 33 there are fuses in the back for LHS and RHS headlight, then there are a couple of doovas in the engine bay listed a "LHS healight" and "RHS headlight" in another fusebox for some reason Even the actual light stalk can have probs which causes the lights to act funny. Autoelec will charge you a couple of hundred at least to fix it.
fully its never ending, got home and felt like selling it, i think im gonna flog the kit off, and get a stock body kit again, when i get some spare cash, or consider a genuine plastic do luck kit from the states
Fark John... Keep your chin up! Your car looks awesome ATM... Pre Skidpan that is... Don't go back to stock!!!
Plastic kit sounds nice though...
yeah know the feeling.. kits can be bitches.. this is my 2nd front bar, and when i get the sideskirts fitted my second lot of them. While being low looks shithot and it handles better, sometimes you gotta wonder. Even with plastic you'll scratch the shit out of the paint and crap.
also mindflux.. just buy a multimeter ($20) and learn how to use it :) That will at least allow you to isolate the problem. You basically just stick the probes at different points and check you're getting voltage at each point. Soon as you find the point where there isn't any voltage anymore that is your prob.
well the box is generic and can vary depending on the options shipped with your car so you might not necessarily have all of them.
you *have* taken the bulb out and checked it haven't you? Bulbs are $7 from anywhere basically. Its always good when you check and it is the bulb, and you go "phew".
I had light probs in my old r31.. cost me $250 or something to get fixed, just for some simply shitty problem.
Guest
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
