hi guys i'm new here. I recently purchased a r33 GTST pretty stockish has a exhaust and front mount cooler and 10psi boost.
I red lined the car today for about a second and something made a slight metal 'ting' sound and now the car drives funny.
The car is completely normal to drive under no boost, however, when you step on in, it only boosts to about 4psi and the induction sound sounds different to what it did before.
also, I didn't have a BOV on my car so it used to flutter before, now, when I release the accelerator, it just makes a funny 'shhhh' sound from somewhere.
I checked all the pipes and simple things like that, but I couldn't find anything?
Could anyone with knowledge about these cars shed some light as to what it might be?
I've tried searching and have found nothing unfortunately.
thanks and peace!
  • Replies 63
im not 100% familiar with RB motors since i am very new to skylines and very rarely work on them but im a mechanic and it sounds like maybe you could have bent one of the butterflys in the intake.
seems to add up to me because the lack of blow off valve would have left excess pressure in the intake when you backed off and a bent butterfly would cause lower vaccum pressure which would then in turn affect the wastegate actuators.
<A name=OLE_LINK73>You can comprar moncler outlet in every tienda moncler and easily find every type of it. The main feature of these leather moncler usa is fabric. Nylon is being used to design these vests which restrict the cool air to come inside your moncler sale body. You won't feel any cold while you are wearing a piece of moncler 2010 on your body. What's most, it is comfortable and light to wear. As we all known, the traditional normal winter Moncler clothing has to been weight and massiness to keep us warmming during cold winters. You have to discard your colorful nice moncler.com and put on thick fat moncler down jackets in order to keep warm. But now, things can be change because of this lightness moncler jacket sale. Its excellent thermal effect, its beautiful design and its comfortable wearing black moncler jacket will give you a warm and pleasant winter. Chaquetas moncler men jacket in striking colors can make your personality superb and this is the best time, when you can purchase your favorite colored moncler jackets. The cheap moncler Kids jackets come at colors such as pink white, blue and black and are cut in moncler sweaters shop way that they give a chic, definite appearance of your figure. You can match moncler jacket women with any of your Moncler jackets for women because its combination enhances your personal. Come with moncler womens jacket, go to the different winter this year. http://www.mcjacketsale.com/
:blink:
His is a GTST, not a GTR, therefore it has one butterly, not 6.
Anyway there really could be a number of possibilities and without knowing the full story every one is simply going to be guessing. Most likely sounds like a small boost leak though.
Edited by PM-R33
as i said im not extremely familiar with the engines, i own a gtr and was going off that.
wouldnt it be good to go off a mechanics guess??? even though it is over the internet
check my option out first, its the easiest, and costs nothing.
Thanks for the opinions. I don't think it would be a boost leak, if it was wouldn't I get boost spicking? Also, I would still get some sort of flutter or bov sound even if it was a boost leak yeah? But thanks again guys, will check the butterfly tomorrow. But if it was the butterfly wouldn't the car run funny the whole way through not just on boost? Thanks again
nah it would still run normal because the computer would compensate.
when i say bent i dont mean bent in half, i mean a slight bow in the butterfly.
I hear what your saying Ben, but that doesnt explain the loud ting at WOT.
Something has broken or split at full power , trozzles idea sounded more plausible..
Or as i said my turbo bolts wound themselves loose and i was having these same symptons.
If your lucky its just a leak somewhere..Keep looking
Edited by Arthur T3
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
