They has less blades with the lower blades removed. I believe it should work well as there are less weight and more passage space.
Its very interesting thou. This type of design was made and used many years ago before the current upper and lower bladed comp wheel was introduced..
So do they have more blades or less? Can someone confirm?
Are they same sorta thing as the GTX40/42/45 turbos that they already sell?
Any significant difference in price for the average Joe?
For those sizes they generally have 12 blades as in 6 tall and 6 short. The one I've seen has only 10 tall blades. I wanted to buy one of those for the ceramic bb turbo that I'm currently working on. Been quoted $1600 just for a comp wheel. Price might come down when its more commercially available.
Have you tried the billet ones on fleabay? Always wondered if they were any good...
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
