We decided on ending up at uriarra east reserve for a bbq and swim. at 1ish pm
how we get there is still up in the air.
I'm keen to head out through tuggers past point hut and go all the way round the back to uriarra.
  • Replies 101
where the heck is uriarra? point hut sounds cool coz thats right out near where i live. Map anyone? :D
follow uriarra rd (past the stromlo mountain bike place) It's not too far from the cotter, kinda the next crossing northwise...
OK. Good idea leaving from grevillia park, as everyone already knows it.
For everyone who's keen for a bit of a cruise before the bbq + swim (I was in the river last weekend and the water was just loverly!), meet up at grevillia park at 11:30am. Talk shit untill 12, then take off.
cruise down the highway past hume, cut through tuggers, then head out past point hut crossing going the back way to uriarra crossing east reserve.
Who's in?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
