but no real benefits?
Take some pressure readings along your exhaust before each component. If you have more than a few psi of presssure anywhere then you have power robbing restriction.
If you have restriction... remove it.
Personally I would go bigger pipe size for that turbo, unless it's a straight pipe with no mufflers.
Cheers
Justin
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5541205
it isn't going to make it worse though
This is what I think, Although after some discussion with some really experienced builders, they think this is not the case.
It is thought that having to big of an exhaust does effect torque. Personally if i was chasing every hp possible i would do what 'XRATED' said, just like inlet lengths need to be tuned so does the exhaust. although turbo cars are no where near as fussy as other cars (after the manifold) it would still make a couple of hp difference.
Edited by phat_man
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5542155
It isn't like an NA car where tuned extractors and smaller pipes to maximise velocity help, on a turbo car the exhaust is under such a high pressure due to the collector you want it as free as possible, I really wouldn't doubt if a straight pipe helped power over the entire graph.
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5542194
With turbos, you just want to get the gasses out of there as fast as possible, any back pressure post-turbine will slow the turbine down.
With long exhausts on a street car, stepping the size of the exhaust down helps maintain velocity. For example, a 4" dump in to a 3.5" front then 3" catback would probably work quite well (or maybe 2x 2.5" so you still get the volume but you increase the velocity).
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5542220
read my post.
you need 4" for 400-440 (t04z) range.
3" will be hurting that setup.
Not true at all, at top end when you are making that kind of power a whole lot of exhaust is bypassing the exhaust via the wastegate...
3" on 26 with T04z regularly make between 430-470rwkw
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5542225
It really depends on your power level.
I'm running a 3in exhaust from cat back. and putting out 350rwkw
i've got a 3in decat, 3.5in muffler and a aftermarket front pipe.
its a pretty straight design with minimal bends. it does the job!
i think if i were heading for closer to the 400rwkw mark i would be looking into a 4in exhaust or at least a 3.5in
i also think that some people get confussed thinking that a bigger exhaust will allow faster spool up, but that's only true if the current exhaust is a restriction at that rpm and load point, which i would higly doubt that a 3in is a restriction at 4,000rpm. it'd be a restriction up higher and when 25psi or more boost starts pumping through the motor.
it might make your decision easier to listen to what a car with a 3in sounds like vs a 4in exhaust, i like my 3in because its quiet enough to not attract too much attention and if flows well enough for my needs.
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5542232
Garrett engineers on their website clearly state that the less restriction after the turbo the better. Sure this needs to be weighed up with physical limitations and noise levels etc. But a greater flowing exhaust can only improve response and top end power. Obviously, whether its even noticeable depends on your power levels but at 400rwkw I think it would be very noticeable.
Just because some cars manage to get 400rwkw through a 3" exhaust doesnt mean they couldnt be a heap better with a larger exhaust.
Min 3.5" IMO
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5542263
Very interesting point, makes sense.
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5542271
    • Nah, don't bother doing any actual measurements on the car. Just go ask the inter-f**king-net.
    • I currently have 18 x 9 +30 on the front with 18 x 10.5 +38 on the rear. Absolutely regretted it. Ended up putting 15 mm spacers on front and 25 mm spacers on the rear. Not to mention the rears were like a mm from hitting the coilovers. Definitely would go more aggressive then what you were originally planning. Keep in mind my guards are rolled and cars fair low so you might possibly need to roll guards depending how aggressive you go and how low the car is. Im not an expert but the 18 x 8.5 +25 18x9.5 +30 Sounds like it would sit much better.
    • Hey guys, sorry i have been researching for a few months and absolutely cannot wrap my head around this. I am about to order some rims to fit my R34 Gtt with coilovers My original plan was to order Rota grid R in 18x8.5 +30 235 40 R18 Fronts 18x9.5 +35 255 35 r18 rears But then the thought in my head said this isnt aggressive enough. I want the most concave spokes i can get without too much of poke and scrubbing   So my thoughts now is  18x8.5 +25 18x9.5 +30   My question is will this be the most aggressive i could get it without any guard rolling and does the type of rim style affect the offset / size.   Thanks everyone.
    • Lower parts are there. On passenger seat, bright yellow bit is the release mount. On drivers, bright yellow bit is the lower buckle for the other side. My bet is lowers are tucked out of the way as much as possible for visuals.
    • I'm guessing its a 4 point harness, 3 of the 4 belts are visible. I'm guessing the hidden belt is tucked down between the seat and door.
