You want an inside one or an engine bay one? I'm going to take a guess that you want an interior one, in which case my comments are going to be pointless :D
I'm using a Turbosmart under bonnet one which is liquid filled. Is a very good price, easily readable and the liquid filling stops the needle from vibrating around giving bad readings. Very happy with it.
Reason I have mine is to check the max fuel pressure for choosing nitrous jetting.
Edited by PM-R33
yep, I use a Defi BF fuel pressure gauge. very good. easy to install, easy to use, easy to read and has one awesome feature I've not seen on any other brand. if you also have the boost pressure gauge (and who hasn't) it can display what they call 'differential pressure' so what it does is remove vacuum or boost from fuel pressure so you can see the actual pressure. this makes it very easy to spot if something's going wrong. see you have the regs base pressure (approx 3 bar in a skyline standard) and then vacuum reduces it, and boost increases it. so when driving it will be fluctuating all over the place. switch the gauge on to diff mode and it should just sit on 3 bar moving only slightly. because it's showing you the difference between total fuel pressure and boost pressure. very handy. and makes it very easy to diagnose any fuel supply problems etc.
I am using one like PM-R33 as i had the same concern as you N1GTR about one of my two bosch 044s failing.
I got mine for about $35 from hi-octane and its bolted on to my SARD fuel pressure regulator.
Though i feel i need one in cabin like Baron as it does sound a lot safer as you'll be able to see it whilst driving. Though it depends if you are willing to spend $300 or so on the defi gauge + another $150 or so on the control unit ;)
I guess you can afford to spend $450 or so after spending that much money and time on your 30/26 right? :bunny:
Thanks guys!
Yes I'm after an inside one, the ones in the engine bay are nice but they're useless when the car is moving. The major concern I've got is that I go for a drive and one fuel pump dies, then stand on the loud pedal and you can all guess the rest :(
Baron I've got the defi triple cluster that replaces the stock dials in the centre, I don't have a seperate boost gauge cause the ebc does that and it's not something I'd look at anyway (there's enough to worry about when you're up it). Does the gauge you've got have a warning or memory recall for a minimum value? The defi gauge in my supra is a bf boost gauge and it has peak recall etc of course with the control box2, but peak isn't a value I want for fuel pressure, if it has a warn at a user defined preset minimum level that would be perfect!
Destrukshn do you have a pic of your one please? I know what you mean, the spending never ends!
Thanks guys!
Yes I'm after an inside one, the ones in the engine bay are nice but they're useless when the car is moving. The major concern I've got is that I go for a drive and one fuel pump dies, then stand on the loud pedal and you can all guess the rest :blush:
yeah just like the fuel pressure gauge the defi fuel pressure gauge has a min warning, and also peak hold and of course record functionality. I would seriously chuck the current boost gauge and controller from the supra into the GTR and add the fuel press gauge to go with it. being able to have it display the differential pressure is a massive advantage over other gauges and really useful. makes it so easy to diagnose reg problems, pump problems etc. and of course you don't have to watch it all the time. can just do a quick run on record then play it back later, or just watch it a bit, set the warning level and then leave it alone. :down:
guise, if you want an in cabbin one what other parts do you need? as above im stressed that my fuel pump is going to die, how do i go about setting up one for the interior? and also some rough prices to on something cheap?
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
