Hi mate
I'm looking to buy a new power fc LCD display, just the display by it self. In the FAQ for the power fc i saw that a blue one is also avalible.
Does anyone knows where i can get one from?
Thanks
i have a gold immamura edition . make me an offer
https://www.sau.com.au/forums/topic/344084-power-fc-help/#findComment-5547035
I think what he means is that he just wants the display, not the whole hand controller, im interested in the same thing if there is a way to do it, most i have seen have just cut up a hand controller.
https://www.sau.com.au/forums/topic/344084-power-fc-help/#findComment-5547216
i brought a seiko one , but i didnt work so dont bother, just buy the EL organic hand controller instead
But where can i get one from. I damaged mine, I then opened up a friends hand held controller for an evo,and removed his LCD display, and it worked in my skyline unit. This is why i'm looking for Just the display rather than buying the whole hand controller.
From what i gather all the LCD displays are the same and can be interchanged.
https://www.sau.com.au/forums/topic/344084-power-fc-help/#findComment-5547306
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
