That sounds like a normal GT3076 that kind of power, keen to see the dyno sheet to see how much laggier it is compared to a GT3076
They stopped intentionaly as I don't have internals. They can see this doing close to 350. No worries.
Will post the sheet when I have it.
100rwkw at 3900rpm is pretty late making power.
Do you have a plot of boost as well? It seems to be in quite late which makes me wonder if there is some improvements to be had with better boost control.
I will get that chart. Definately. I'm using a gizzmo IBC. U recon a better one will bring.power on sooner.
thats worse than my 3076r. mine makes 270@16psi on a mainline for reference internally gated
Don't look at power every dyno is different. Shape of chart is more important. So its laggier than gt3076?
.63 or .82 rear? internally gated or external?
it 'looks' a touch laggy. how does it drive?
.82
Drives very smooth. Have to admit. I wouldn't mind removing a big of lag. Just a bit. However im coming from stock turbo maybe om not that used to it. Wat things can reduce lag? Once it up and boogies it pulls like a freight train though. Lol
Really? Wasnt their goal to bring boost on earlier with the gtx?
Compare the flow maps, they flow more in the higher boost levels mainly, but also tend to be more comparable with a slightly bigger version of the same turbo. Read all of this thread, lots of pretty graphs to look at.
What made you think that?
Edited by Rolls
4800rpm for 200rwkw, ugh... Much lagging compared to a 3076
But its similar to a GTand that's pretty much where a GTX3076 sits for comparo.
unfortunately it seems Garretts GTX3x frame isn't living upto the claims
Ah ok. Have read all of the thread will be looking at getting a 3076 soon.
Dont know how I got that idea, mabey just saw the new model and presumed it would be better haha.
i would be interested to see a plot of a GT3040 (GT3082R) Vs' a GTX3076R as i think they will be pretty similar.
Personally i think that that GTX range was an attempt to gain back a bit of the market share that they were beginning to lose to other performance turbo brands like Precision and Borg Warner. They seem to have been caught napping a bit and while the others were designing completely new turbos Garrett were relying on their now old GT range and didn't seem to be working on anything new.
That is also the reason why i think that the wheels are billet as the time from design to production is a lot less with a billet part than cast, and it also means that they can easily tweek the design without the expense of re tooling.
The GTX range at the end of the day is nothing more than an updated compressor, it's not a completely new turbo just a touch up on the old design.
Edited by D_Stirls
I do remember the first releases on the GTX implied they would be at least as responsive as the GT, but I have been suspicious of that claim from the start... however this result looks too laggy. I suspect something isn't right somewhere, probably a leak of some sort more than boost control.
For what its worth, the GTX3076R would really be a GTX3077R if Garrett stuck to their normal naming conventions.
Anyone else actually got one of these? So I can compare how abnormally lsggy might e is. Ugh.
Someone previously posted on here (I think it was Ozz) on an SR20 they were virtually identical - you'd be forgiven thinking they were the same turbo on different dyno runs.
Found it on another forum - scroll down to post 37.
http://www.silviawa.com/forums/index.php?showtopic=58974&st=20
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
