Hey guys I have a few items off my 34 gtt for sale
Everything can be picked up in Frankston Vic.
Its all in good condition everything for sale has simply been replaced with upgrades.
Standard R34 GTT OP6 turbo - $400
Done about 130k KMs, never had a problem with it, comes with the standard actuator and the 90 degree elbow. OP6 rear housing good for high flows (better than r33 turbos). Only trouble is 2 bolts on the exhaust housing where it bolts up to the exhaust had the ends snapped off them :D , still a lot of meat sticking out so it shouldn't be too hard to get them out.
post-66560-1289883952_thumb.jpgpost-66560-1289884045_thumb.jpgpost-66560-1289884057_thumb.jpgpost-66560-1289884134_thumb.jpg
HKS adjustable wastegate actuator with bracket - $90
Bolts right where the standard actuator usually is, turn your boost up without a boost-T or ebc :( .
R34 GTT standard side mount intercooler - $150
Comes with the brackets to mount it and the plastic shroud
R34 GTT standard wheels with tyres - $400
225/45/R17 Zeetex HP102 tyres (from compliance :D ) heaps of tread left. Bit of gutter rash, see photos.
JJR 3" stainless steel bellmouth front/dump pipe - $100
Lines up with standard turbo and standard cat locations
R34 GTT stock clutch and flywheel - $150
send it to jim berry or something
R34 GTT stock injectors - $60
With plugs
R34 GTT Stock fuel pump - $60
R34 GTT stock AFM (pink label) - $100
comes with plug too
Edited by MrTerry
https://www.sau.com.au/forums/topic/344501-r34-gtt-parts/
would you swap the wheels for a decent condition sr3 recaro plus cash my way?
my number is 0435767585 if your interested
cheers. ken
sorry ken just after cash at the moment, thanks for the offer though.
https://www.sau.com.au/forums/topic/344501-r34-gtt-parts/#findComment-5567756
are u interested in shipping the intercooler to brisbane, or pickup only? i'm chasing one...
Yeah I can ship, im not sure how much it'll cost i dont mail things very often :/
if you definately want it send me a pm and ill work out the shipping cost on monday.
https://www.sau.com.au/forums/topic/344501-r34-gtt-parts/#findComment-5569139
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
