The annual SAU Dyno Day - Register your interest NOW
Steve, any word on the TV?
Just a thought, I think MattR mentioned it before - name tags!!! I have only ever met a few people of SAU, and being a printer perhaps I can print some up?? Will just need a confirmed list of people, it wouldnt be hard at all
  • Replies 228
Ahh mate it's probably not the place to be posting my dramas, but what the hell why not....  I'm not far off being on the single scene again, after 7+yrs & a 17mth old bub. Ahh well, these things happen.
Well that makes two of us. :)
:grouphug: for whatsisname, cheeky and t-man
chins up
and remeber, we all love you guys (except TIMMMAAYY, cos he is a bit scared it may have nutman connotations:p)
Chris32, not sure yet, I think matt was going to sus things out, but I will be in there on monday morning, so I shall see what shaun says
hippy - no
fark guys whats goin on..... hope everyone works things out, well i just want everyone happy.
Steve, i will b there if u can gaurentee a tv which has clear channel 10 reception. im a hardcore ferrari fan!!!!!!
Hip: g1 practice day is on that day mate.
chins up
steve are you sure you are on the right side of the fence :headspin:
I've nearly got my shit sorted. so its all good almost. w00t
you and you're ferrari's dean :D
eeew Ferrari fan :freak:
Sorry this has nothing to do with the DYNO but I have a question It is about my GTR as I was leaving my house I was driving to the main road and I noticed a little noise from the front of the car when I took off it sounded like a sweeeek sorta like slipping, has anyone have any idea I think the shocks are Ok but I am lost with this one.
Well that makes two of us. :P
For what it's worth Erica, I know how your feeling.
Steve,
I haven't got around to talking to Shaun re a TV for the dyno day, but I'll ring him later today.
Not sure about your problem mate but back to the 4WD vs 2WD dyno bit, you should be able to remove the FWD fuse to make it RWD only. I think that's right? So you should come along and throw it on.
you and you're ferrari's dean ;)
sorry if I took you out of your comfort zone.... didnt realise you were a homophobe:p I have edited my post for you:)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
