The annual SAU Dyno Day - Register your interest NOW
  • Replies 228
I'm looking forward to seeing all these cars and seeing what numbers they run.
I finally got my FMIC installed today so hopefully I won't be completely embarrassed. I'm bloody annoyed though that my ebc hasn't arrived in the post yet so I can get everything tuned up properly. At least it will be interesting to see what just a bigger exhaust and FMIC combo will run over my previous run on the dyno when everything was stock - 105rwkw!! I think the dyno operator said something like "better not let this one get away from ya".
Fingers crossed it's not gonna be too hot - it seems it always is whenever there is a drag, drift or dyno event on!!
doglet, its not just about big power, its about seeing where your car is at, and at the same time, it will provide some valuable info for people looking at doing different mods cos we can all compare on the same dyno on the same day with different levels of mods.
Matt, yeah what T-man said:)
Yeah I know it's not all about big numbers but it'll be nice to see some higher numbers with the bigger amount of cash that has recently been spent! :( Hopefully it won't be like my ex- girlfriend where I ended up getting not much in return after all the money I spent! hehehehe
Looking forward to seeing some R32's with RB20DET's still under the bonnet ;) so I can see where I am heading.
I'll be there mate, nothing wrong with the old RB20's :( No doubting how effective the RB25/30 swap is though, considering it cost similar dollars to build a fresh RB20 or RB25/30, you'd be crazy not to think about doing the swap if your motor died!
Will be good to see some big power cars though, cant wait
Hey matt/steve : do u think shaun would mind if i just had a look at the setting on my cam gear. I have checked them and it seems to be 2-3 notches to the left looking front on.
What does this equate to?
Joel: Do u think the dodgy wastegate mod of urs would work on my car. Im having problems holding any more then 13psi over 5000rpm.
Yer it would work. It takes a bit of fiddling to get right.
When adjusting it, it might be worth pulling all the timing & pumping as much fuel as you can in to it so when you send boost over 15psi for a second it won't damage anything.
I did call it bodgy for a reason though. :(
heheh would i be able to do this. WHat toolz will i need, as i have a huge tool kit, i will just need to by the equipment.
By asjustin the wastgate, will this change to boost pressure, or just allow it to hold better.
Oh oh....
NO saturday for me.. :)
I have to work with my old man.
I really need the money as I havn't bought books for Uni yet.. Instead blowing it on the Motor. As you can see I've got my priority's sorted.. :)
Enrico,
I've got a pic of the wastegate when I pulled it off I'll edit it so you know what it should look like.
basically you just elongate the holes so you can pull the turbo away from the turbo (towards the front of the car).
It reduces the travel of the wastegate actuator so in turn the wastegate flap never fully opens hence boost will hold in the higher rev's.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
