The annual SAU Dyno Day - Register your interest NOW
  • Replies 228
I'm looking forward to seeing all these cars and seeing what numbers they run.
I finally got my FMIC installed today so hopefully I won't be completely embarrassed. I'm bloody annoyed though that my ebc hasn't arrived in the post yet so I can get everything tuned up properly. At least it will be interesting to see what just a bigger exhaust and FMIC combo will run over my previous run on the dyno when everything was stock - 105rwkw!! I think the dyno operator said something like "better not let this one get away from ya".
Fingers crossed it's not gonna be too hot - it seems it always is whenever there is a drag, drift or dyno event on!!
doglet, its not just about big power, its about seeing where your car is at, and at the same time, it will provide some valuable info for people looking at doing different mods cos we can all compare on the same dyno on the same day with different levels of mods.
Matt, yeah what T-man said:)
Yeah I know it's not all about big numbers but it'll be nice to see some higher numbers with the bigger amount of cash that has recently been spent! :( Hopefully it won't be like my ex- girlfriend where I ended up getting not much in return after all the money I spent! hehehehe
Looking forward to seeing some R32's with RB20DET's still under the bonnet ;) so I can see where I am heading.
I'll be there mate, nothing wrong with the old RB20's :( No doubting how effective the RB25/30 swap is though, considering it cost similar dollars to build a fresh RB20 or RB25/30, you'd be crazy not to think about doing the swap if your motor died!
Will be good to see some big power cars though, cant wait
Hey matt/steve : do u think shaun would mind if i just had a look at the setting on my cam gear. I have checked them and it seems to be 2-3 notches to the left looking front on.
What does this equate to?
Joel: Do u think the dodgy wastegate mod of urs would work on my car. Im having problems holding any more then 13psi over 5000rpm.
Yer it would work. It takes a bit of fiddling to get right.
When adjusting it, it might be worth pulling all the timing & pumping as much fuel as you can in to it so when you send boost over 15psi for a second it won't damage anything.
I did call it bodgy for a reason though. :(
heheh would i be able to do this. WHat toolz will i need, as i have a huge tool kit, i will just need to by the equipment.
By asjustin the wastgate, will this change to boost pressure, or just allow it to hold better.
Oh oh....
NO saturday for me.. :)
I have to work with my old man.
I really need the money as I havn't bought books for Uni yet.. Instead blowing it on the Motor. As you can see I've got my priority's sorted.. :)
Enrico,
I've got a pic of the wastegate when I pulled it off I'll edit it so you know what it should look like.
basically you just elongate the holes so you can pull the turbo away from the turbo (towards the front of the car).
It reduces the travel of the wastegate actuator so in turn the wastegate flap never fully opens hence boost will hold in the higher rev's.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
