How much ignition are you running in your RB20 tune? It looks one the boost hits there isnt really much gained hp wise from more revs and the torque seems to die off real quickly.
The RB25 setup with the T67 looks the goods!
As much as it took without stopping making power... I think it was around 26 top end but don't quote me on that! Wouldn't ping regardless haha
That might be the small ports/factory intake etc holding the RB20 back, what turbo was on the 20 Simon?
Hypergear ATR43G3 0.63
Actually ended up going 517rwhp (386rwkw) without correction...
So that is a 127hp more than the RB20, plus it's 700rpm quicker to come on boost and nearly doubles torque between 3000rpm-5000rpm
Does nothing but burnouts in pretty much all gears
awesome build man nice power curve as well, and i'm tossing between this T67 vs GT35r -82r or GTX35r for my RB30det build
but i am on limited budget (2500) if you dont mind me asking how much is this turbo setup roughly ? turbo+gate and mani cheers
GTX35r are still very expensive and without exaust housing so my main choise would be T67 or GT35r looking for 400kw
I would go this any day over a GT3582R, I have a pretty low opinion of them. The will probably make a bit more power but a fair bit laggier... GTX3582R is massive so you would probably be better at looking at a GTX3076R for similar sizing!
Turbo $879
Manifold $1300
Gate $375
If you were doing a Garrett add about a extra $500 for braided lines and double the price of the turbo (GTX probably a bit more)
mebbe...but i dont buy into that snmall port thing. An RB20 has larger valve area per cylinder then an SR20 so dont see that as being the problem. You only need ports and valves mig enough to cover the displacement of each cylinder...other wise velocity, cylinder filling etc goes to crap. Probably more to do with teh lil internal gate turbo with a small housing on funny fuel meaning the thing had so much back pressure it woudldnt take any ignition up top ?!?!?!?
Not sure what the issue was, it really did hit a brick wall at that power... but I'm pretty sure it had plenty of timing top end :)
Edited by SimonR32
  • 3 weeks later...
Out with the old Bride Brix...
and in with the new, Bride Zeta II :)
Was in pretty average condition yesterday, gave it a nice clean and a bit of a fix up last night and looks heaps better now. Going to try a few things with it soon to get it looking nice and fresh soon. The old Brix will end up my passenger seat when I can find or swap my drivers rail for a passenger one.
Getting ready to track the Booga a fair bit soon so thought it might be a good idea to try and drop under bonnet temps a little bit... First on the list a Turbo Beanie and also have a roll of heat wrap that I'm going to do the dump with on the weekend :)
Did the heat wrap on the dump today and finally got around to taking it for a quick burst with the new turbo bag (in the 38 degree heat)... All went really well, got back and could put my hand on the turbo bag for a few seconds so I guess the heat would have been around 70deg which would be several hundred lower than what it was originally. Dump was also cool enough for a quick touch.
The whole engine bay is now a fair whack colder, so job done. Now just time to get it back on the dyno :)
Went back for a touch up on the tune last night...
Ran a bit more boost and a bit more revs and it made a little more top end and mid range, also set up low boost for track work at 1.3bar and made 350rwkw or 475rwhp!
Here is the graph of the high boost run (note that correction being put on made a extra 20rwkw) so pretty similar top end to my last run
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
