If BWRGTR dosent buy these. Pm me. I'll take em
its your for the taking mate, missus aint keen to have the car off the road again so soon after my clutch packed up recently
My they are expensive lol. That's 100% market bloat. They'll still sell at that price sadly.
lol, its pretty much the going rate around these parts, how much u getting em there for aye?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
