Hey all,
I spent a good couple of days last week reading all the threads in the FI section and the general maintenance section to make sure I bought the right spark plugs for my car, and I ended up going with NGK Iridium BKR7EIX which are gapped to 0.8mm from factory; only put them in my car on Friday.
But my car is now with Andrew at Hyperdrive waiting to go on the dyno and he called me up to ask what plugs I have. When I told him, he said they are definitely going to have to come out, the plugs need to be gapped to a maximum of 0.7mm but ideally 0.65mm. So it appears I have wasted a hell of a lot of money as the Iridiums can not be regapped and now Andrew thinks he will needs to waste dyno time seeing if they will misfire, then waste time removing the plugs and replacing them, etc.
But wherever I look on SAU, everyone recommends using 0.8mm gaps for boost over 12psi. I'm not sure what boost he is intending to run, I know the turbo I'm using has a 20psi atmospherical actuator so low boost will probably be around 15-18psi. I had been expecting the car to make between 350-380rwhp on high boost. Are his fears correct and I've made a mistake choosing those plugs, or am I getting in a panic over nothing?
Cheers,
Martin.
https://www.sau.com.au/forums/topic/345346-spark-plugs/
I went to the drags last week and was miss-firing down the strip, that was about 1.3 bar and the plugs are ~7,000kms old. It got worse as the night progressed :blink: Still, I managed at 13.036.
I think next plug change I'll be looking to re-gap below 0.8mm, but I just use copper plugs. Why can't you re-gap iridiums?
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5563856
Yeh and KYP have put all sorts of sensors on the valley cover that need to be unplugged and removed. Took me about 3 hours to do it on Friday, but it was the first time I've done it on a Skyline. Could probs do it quicker next time.
I just got Iridiums because I figured it's better to spend $85 once every 60000kms than however much coppers cost every 5000kms.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564031
i have a brand new set of the copper plugs you need sitting here if you need them asap
gap depends on a few things, mainly boost and condition of your coilpacks. but unless you have some really good coilpacks you'll need a smaller gap than .8 for 15+psi
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564365
When i used splitfire coilpacks i was running .8mm or maybe a bigger gap and no misfires with 18psi.
I always replaced my sparkplugs every 5000kms with copper ones.
If you are running original coilpacks, i would gap a set of copper plugs down to .6mm to stop the misfire problems on high boost.
Otherwise get a set of aftermarket coilpacks and stick to the iridiums since you have trouble taking out the sparkplugs.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564614
Bro, if your actuator has a spring pressure of 20psi you wont be able to run under that boost pressure...
Yeh 20psi atmospherical, so at the manifold will be 15-18psi. What I've been told anyway... My boost gauge reads 16psi with the boost controller switched off, so I guess that's correct.
coppers all the way man, do not bother with iridiums - you should have picked up on that if you did read all the threads :P
change them every 2nd or 3rd oil change :)
I know, everyone vouches for coppers but I went for Iridiums because I didn't want to be changing plugs every 5000kms lol. I will probably go with coppers next time.
Anyway, car doesn't have any issues as far as I know... I have Splitfire coilpacks. It does have a slightly rough idle like it's misfiring at idle but I thought that is more likely from the 650cc injectors not the spark plugs???
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564768
5000kms is far too early for coppers!
ive done 12,000km on mine (bcpr7es), still like new and never mis fired - I run a heat range 7 though as i dont waant any chance of pre-ignition although a 6 would be better for a daily driven car but eh, better safe than sorry
ill change mine at 15,000km even though i know they will go more, just good to keep it routine instead of waiting for a failure
Edited by snozzle
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564769
Use NGK copper BCPR7ES and gap to .8 and will be sweet
Try for the ones without the R if you can though. From memory, the R is a resistor type or something and has a slightly weaker spark... but it's there to reduce electronic knocking/pulses? I should google it- no wait, you google it for a better answer.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5565355
This. Dont know why everyone does it at 5,000km. When I pull them out after 10,000km they still look fine.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5565358
Probably depends on your tune/mods and how you drive as well I guess. You're a pussy driver and have no fast and furious mods, so yours last longer :bunny:
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5565367
I am using irridium plugs and have been for the past year or so. No problem what so ever with them. on low or high boost and they are gapped at 0.8... and I am still using standard coilpacks at the moment as they are still going strong.
I used them for the same reason as Hanaldo... I didnt want to unplug / unscrew everything every 5k or so...
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5566341
The trionic system uses the resistor ® type spark plug to read combustion chamber conditions and "inform" the ECU about boost and ignition advance requirements for the engine in real time and continuously. This is why you must use resistor type plugs
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5566350
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
