Hey all,
I spent a good couple of days last week reading all the threads in the FI section and the general maintenance section to make sure I bought the right spark plugs for my car, and I ended up going with NGK Iridium BKR7EIX which are gapped to 0.8mm from factory; only put them in my car on Friday.
But my car is now with Andrew at Hyperdrive waiting to go on the dyno and he called me up to ask what plugs I have. When I told him, he said they are definitely going to have to come out, the plugs need to be gapped to a maximum of 0.7mm but ideally 0.65mm. So it appears I have wasted a hell of a lot of money as the Iridiums can not be regapped and now Andrew thinks he will needs to waste dyno time seeing if they will misfire, then waste time removing the plugs and replacing them, etc.
But wherever I look on SAU, everyone recommends using 0.8mm gaps for boost over 12psi. I'm not sure what boost he is intending to run, I know the turbo I'm using has a 20psi atmospherical actuator so low boost will probably be around 15-18psi. I had been expecting the car to make between 350-380rwhp on high boost. Are his fears correct and I've made a mistake choosing those plugs, or am I getting in a panic over nothing?
Cheers,
Martin.
https://www.sau.com.au/forums/topic/345346-spark-plugs/
I went to the drags last week and was miss-firing down the strip, that was about 1.3 bar and the plugs are ~7,000kms old. It got worse as the night progressed :blink: Still, I managed at 13.036.
I think next plug change I'll be looking to re-gap below 0.8mm, but I just use copper plugs. Why can't you re-gap iridiums?
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5563856
Yeh and KYP have put all sorts of sensors on the valley cover that need to be unplugged and removed. Took me about 3 hours to do it on Friday, but it was the first time I've done it on a Skyline. Could probs do it quicker next time.
I just got Iridiums because I figured it's better to spend $85 once every 60000kms than however much coppers cost every 5000kms.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564031
i have a brand new set of the copper plugs you need sitting here if you need them asap
gap depends on a few things, mainly boost and condition of your coilpacks. but unless you have some really good coilpacks you'll need a smaller gap than .8 for 15+psi
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564365
When i used splitfire coilpacks i was running .8mm or maybe a bigger gap and no misfires with 18psi.
I always replaced my sparkplugs every 5000kms with copper ones.
If you are running original coilpacks, i would gap a set of copper plugs down to .6mm to stop the misfire problems on high boost.
Otherwise get a set of aftermarket coilpacks and stick to the iridiums since you have trouble taking out the sparkplugs.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564614
Bro, if your actuator has a spring pressure of 20psi you wont be able to run under that boost pressure...
Yeh 20psi atmospherical, so at the manifold will be 15-18psi. What I've been told anyway... My boost gauge reads 16psi with the boost controller switched off, so I guess that's correct.
coppers all the way man, do not bother with iridiums - you should have picked up on that if you did read all the threads :P
change them every 2nd or 3rd oil change :)
I know, everyone vouches for coppers but I went for Iridiums because I didn't want to be changing plugs every 5000kms lol. I will probably go with coppers next time.
Anyway, car doesn't have any issues as far as I know... I have Splitfire coilpacks. It does have a slightly rough idle like it's misfiring at idle but I thought that is more likely from the 650cc injectors not the spark plugs???
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564768
5000kms is far too early for coppers!
ive done 12,000km on mine (bcpr7es), still like new and never mis fired - I run a heat range 7 though as i dont waant any chance of pre-ignition although a 6 would be better for a daily driven car but eh, better safe than sorry
ill change mine at 15,000km even though i know they will go more, just good to keep it routine instead of waiting for a failure
Edited by snozzle
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564769
Use NGK copper BCPR7ES and gap to .8 and will be sweet
Try for the ones without the R if you can though. From memory, the R is a resistor type or something and has a slightly weaker spark... but it's there to reduce electronic knocking/pulses? I should google it- no wait, you google it for a better answer.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5565355
This. Dont know why everyone does it at 5,000km. When I pull them out after 10,000km they still look fine.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5565358
Probably depends on your tune/mods and how you drive as well I guess. You're a pussy driver and have no fast and furious mods, so yours last longer :bunny:
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5565367
I am using irridium plugs and have been for the past year or so. No problem what so ever with them. on low or high boost and they are gapped at 0.8... and I am still using standard coilpacks at the moment as they are still going strong.
I used them for the same reason as Hanaldo... I didnt want to unplug / unscrew everything every 5k or so...
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5566341
The trionic system uses the resistor ® type spark plug to read combustion chamber conditions and "inform" the ECU about boost and ignition advance requirements for the engine in real time and continuously. This is why you must use resistor type plugs
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5566350
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
