Clearing parts that i have stored up. Parts come from S1 and S1 R33 skylines. Some R32 gear and aftermarket as well.
Heaps of interior parts from S2 r33 avaliable
Take a look and PM me if you need anything not listed.
#1 R33 Series 1 spoiler (black) $50 ono
#2 Unknown Brand Cannon $30
#3 Apexi BOV (ok condition, gr8 sound) $50 each (got two)
#4 Series 2 two door tail lights and rear garnish $100 (white)
#5 Series 2 dash (ok conditon) $100 ono
#6 Rear Hicas unit x 2 $50
#7 R33 fuel tank x2 (gd condition) $50 ono
#8 Passengers Side Mirror (White) $50
#9 Passengers door trims (gd condition) $20 each
#10 Front hubs (LH and RH avaliable, 5 stud) $50 each
#11 Front Assemblies (knuckles and upper arms) $50 each
#12 Rear seat (gd condition) $50 ono
#13 Complete Dash loom $30
#14 Petrol Flapper/door $10
#15 Rear 2 door interior quarter panels $20 each
#16 Windscreen Washer Bottle $20
#17 Set of 17"x7" rims (good tires on 2, other 2 need replacing), $600 ono
minor gutter rash but overall pretty good, (will not fit over large brake calipers)
#18 A Pillar trims (no holes for gauges etc) $20 each
#19 Accelerator Pedal and Cable $40
#20 Drivers and passengers side seat belt S2 $15 each
#21 Steering Column with Barrel, Key and Trim surrounds $80
#22 Hks SSQ (gd condition) with rb25 adaptor $70
#23 Front RH and LH Guards (White in colour and gd condition) $80 each
#24 Reo Bar for behind R33 S2 Dash (Straight and good condition) $40
#25 R33 Engine Crossmember $50
#26 Stock R33 Turbo Actuator $40
#27 Flywheel and Bolts $80
#28 Extreme Heavy Duty Clutch and Pressure Plate (gd condition, hardly used) $100
#29 R33 Brake Booster and Cylinder (no plundger) $50
#30 R32/33 Stainless Steel Intercooler piping $100
#31 Manual R33 Brake Pedal $30
#32 Heater core/Unit from an R33 $40
#33 SRS Passengers Airbag, S2 Steering Wheel with Airbag and Airbag Module $make an offer$ (not activated)
#34 S2 Pink Label AFM $110
#35 Stock Rear Bar for an R33 (need respray) $40
#36 LH Black Front Guard $80
#37 Apexi Alloy Radiator (comes with Apexi cap, holds pressure, slight fan marks on some fins, overall gd condition) $250
#38 Front Rad support (Straight and in gd condition) $175
#39 Rear Cradle (minus diff and half shafts) $75
#40 S2 R33 Rear Strut Brace (standard) $100
#41 Black S2 Boot with S2 Spoiler ( great condition) $150
#42 Passengers Door (gd condition) minus mirror $85
#43 Rear Windscreen $75
#44 Side windows $30 each
#45 S2 Manual cluster with 96 xxx kms $125
#46 Auto Cluster $50
#47 S2 Glove Box (great condition) $50
#48 Manual Clutch pedal $40
#49 Slave cylinder with lines and fork piston etc $ 40
#50 S2 Front Grill Black in colour $50
ALL PRICES ARE (ONO)
PICS ON REQUEST
Happy to Post items at buyers expense.
https://www.sau.com.au/forums/topic/345462-wrecking-r33-s2/
Pass seat belt - sold
centre console coin holder - sold
hks ssq bov - sold
drivers seat belt buckle - sold
interior door handles - sold
window motor drivers - sold
Plenty more parts to clear ....
https://www.sau.com.au/forums/topic/345462-wrecking-r33-s2/#findComment-5573540
R33 S2 engine harness and ECU?
used them in my car buddy
have you got the stock turbo lines and banjo fittings?
just pulled them off my own car last night as i upgraded
not sure if i want to let them go but pm me and offer and i might be willing
https://www.sau.com.au/forums/topic/345462-wrecking-r33-s2/#findComment-5579341
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
