Clearing parts that i have stored up. Parts come from S1 and S1 R33 skylines. Some R32 gear and aftermarket as well.
Heaps of interior parts from S2 r33 avaliable
Take a look and PM me if you need anything not listed.
#1 R33 Series 1 spoiler (black) $50 ono
#2 Unknown Brand Cannon $30
#3 Apexi BOV (ok condition, gr8 sound) $50 each (got two)
#4 Series 2 two door tail lights and rear garnish $100 (white)
#5 Series 2 dash (ok conditon) $100 ono
#6 Rear Hicas unit x 2 $50
#7 R33 fuel tank x2 (gd condition) $50 ono
#8 Passengers Side Mirror (White) $50
#9 Passengers door trims (gd condition) $20 each
#10 Front hubs (LH and RH avaliable, 5 stud) $50 each
#11 Front Assemblies (knuckles and upper arms) $50 each
#12 Rear seat (gd condition) $50 ono
#13 Complete Dash loom $30
#14 Petrol Flapper/door $10
#15 Rear 2 door interior quarter panels $20 each
#16 Windscreen Washer Bottle $20
#17 Set of 17"x7" rims (good tires on 2, other 2 need replacing), $600 ono
minor gutter rash but overall pretty good, (will not fit over large brake calipers)
#18 A Pillar trims (no holes for gauges etc) $20 each
#19 Accelerator Pedal and Cable $40
#20 Drivers and passengers side seat belt S2 $15 each
#21 Steering Column with Barrel, Key and Trim surrounds $80
#22 Hks SSQ (gd condition) with rb25 adaptor $70
#23 Front RH and LH Guards (White in colour and gd condition) $80 each
#24 Reo Bar for behind R33 S2 Dash (Straight and good condition) $40
#25 R33 Engine Crossmember $50
#26 Stock R33 Turbo Actuator $40
#27 Flywheel and Bolts $80
#28 Extreme Heavy Duty Clutch and Pressure Plate (gd condition, hardly used) $100
#29 R33 Brake Booster and Cylinder (no plundger) $50
#30 R32/33 Stainless Steel Intercooler piping $100
#31 Manual R33 Brake Pedal $30
#32 Heater core/Unit from an R33 $40
#33 SRS Passengers Airbag, S2 Steering Wheel with Airbag and Airbag Module $make an offer$ (not activated)
#34 S2 Pink Label AFM $110
#35 Stock Rear Bar for an R33 (need respray) $40
#36 LH Black Front Guard $80
#37 Apexi Alloy Radiator (comes with Apexi cap, holds pressure, slight fan marks on some fins, overall gd condition) $250
#38 Front Rad support (Straight and in gd condition) $175
#39 Rear Cradle (minus diff and half shafts) $75
#40 S2 R33 Rear Strut Brace (standard) $100
#41 Black S2 Boot with S2 Spoiler ( great condition) $150
#42 Passengers Door (gd condition) minus mirror $85
#43 Rear Windscreen $75
#44 Side windows $30 each
#45 S2 Manual cluster with 96 xxx kms $125
#46 Auto Cluster $50
#47 S2 Glove Box (great condition) $50
#48 Manual Clutch pedal $40
#49 Slave cylinder with lines and fork piston etc $ 40
#50 S2 Front Grill Black in colour $50
ALL PRICES ARE (ONO)
PICS ON REQUEST
Happy to Post items at buyers expense.
https://www.sau.com.au/forums/topic/345462-wrecking-r33-s2/
Pass seat belt - sold
centre console coin holder - sold
hks ssq bov - sold
drivers seat belt buckle - sold
interior door handles - sold
window motor drivers - sold
Plenty more parts to clear ....
https://www.sau.com.au/forums/topic/345462-wrecking-r33-s2/#findComment-5573540
R33 S2 engine harness and ECU?
used them in my car buddy
have you got the stock turbo lines and banjo fittings?
just pulled them off my own car last night as i upgraded
not sure if i want to let them go but pm me and offer and i might be willing
https://www.sau.com.au/forums/topic/345462-wrecking-r33-s2/#findComment-5579341
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
