Hi,
I've got a R32 gtst and my front coilovers are ont he way out and I'm about to buy some new ones.
I was wondering how bad softer spring rates on the front would be?
Right now I have 8kg rates int he back and the coilovers I want for the front are 6 or 7kg's.
Is this a terrible idea? It would be mainly for street driving and drifting once a month.
Thanks!
https://www.sau.com.au/forums/topic/345610-higher-rear-spring-rates-bad/
not terrible, but unwise, depending on your ARB rates, and at a long shot, ur RC heights.
inducing huge oversteer doesnt really help anything, circuit it just makes the car shit to drive, auto/motokhana it makes the car shit to launch, and drift it makes the car lack any ability to hold high angle (although making it easy to an amateur to initiate)
I dont think the differences will be massivly drastic.
And its not a bad idea.
You may have to adjust the way you drive a little and prepare to catch the car when your giving it a poke.
Softer springs in the front will increase complience in the front and decrease understeer, making it want to oversteer.
You can tune out some of the oversteer if your THAT worried about it by running 1-2mm of toe in on each wheel at the rear and getting the camber settings right at the rear. Also, you can run lower tyre pressures in the rear. If you can, soften the dampers at the rear and soften swaybar if you can adjust it.
well soft springs...say king springs will make the car comfortable but handle like shit as you do want some amount of hardness. the usual spring rate is 8 front 6rear for s13 sr/ca but for a r32/a31/s13 with a rb in it 10 front 6 rear
Edited by Dan_J
6 or 7kg front and 8kg rear will be nasty to drive and you'd really want to be on-the-ball if it ever rained. Trust me. I actually play around with different spring rates on my track car, not just make a guess and say "I doubt it will be a big deal". Even 25lb/in increments (half a kg/mm) make big differences.
"Softening shocks" will not change the mid corner balance, that's all down to spring rate. Shocks affect transient behaviours - change of directions, bumps etc.
The sensible thing to do is put the current 8kg rear springs on the front coilovers, get the 6kg springs with the new coilovers and fit them on the rears. 7kg would still be taily with 8kg fronts.
What's the current front spring rate?
  • 4 weeks later...
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
